kyzinayana
Натяжные потолки
Отличаются ли чем-нибудь натяжные потолки от навесных? Я в этом ничего не понимаю, надо заказать сделать потолки, но вот где и какие....?
Может быть, сможете посоветовать что-нибудь?
Позвоните в какую-нибудь фирму и помучайте их :)
Если хотите личных рекомендаций... У меня знакомый заказывал потолки Олимп http://www.arcades.ru
Сделали очень красиво. Думаю, Вас смогут проконсультировать... на сколько я понимаю - с их установкой не все так просто, как Вы думаете.
The Sharing Of Marriage (humor)
The old man placed an order for one hamburger,
French fries and a drink.
He unwrapped the plain hamburger and
carefully cut it in half, placing one half in front of his wife.
He then carefully counted out the French fries, dividing them into two piles and neatly placed one pile in front of his wife.
He took a sip of the drink, his wife took a sip and then set the cup down between them
.... As he began to eat his few bites of hamburger, the people around them were looking over and whispering.
Obviously they were thinking, 'That poor old couple - all they can afford is one meal for the two of them.'
As the man began to eat his fries a young man came to the table and politely offered to buy another meal for the old couple. The old man said, they were just fine - they were used to sharing everything
People closer to the table noticed the little old lady hadn't eaten a bite. She sat there watching her husband eat and occasionally taking turns sipping the drink.
Again, the young man came over and begged them to let him buy another meal for them.
This time the old woman said 'No, thank you, we are used to sharing everything..'
Finally, as the old man finished and was wiping his face neatly with the napkin, the young man again came over to the little old lady who had yet to eat a single bite of food and asked 'What is it you are waiting for?'
She answered
_______________________
money
    • Автор: Anastasia2604
      Какие лучше сделать потолки в доме? Может натяжные? Может навесные? Может пластиковые? Может просто покрасить? А каким цветом? Долго думала и остановилась все таки на натяжных потолках которые заказала здесь https://www.domashniy-uyut.net/potolki/ и как то совсем не пожалела. Все таки натяжные потолки это красиво, и недорого, и надолго, ведь правда?
    • Автор: Skeptik1
      Вставая перед выбором теплоизоляционного материала для будущего или уже существующего дома, большинство из нас начинают заботить сразу несколько вопросов, таких как - теплоизоляционные и шумоизоляционные свойства материала, срок его службы, экологичность, пожаробезопасность, и, собственно, стоимость.
      В настоящий момент Российский рынок предлагает четыре основных вида теплоизоляционных материалов:
      -утеплители на основе минеральной ваты или базальта (их мы рассмотрим как одну группу, так как по большинству показателей эти два материала схожи), для сравнения возьмем теплоизоляционные плиты плотностью 80 кг/м3, поскольку применение материала именно такой плотности рекомендует производитель при строительстве жилых помещений;
      -пенополистирол- он же ПСБС или пенопласт, для сравнения возьмем ПСБС плотностью 35 и группой горючести Г1 (материалы с более высокой группой горючести применять опасно);
      -экструдированный пенополистирол- он же изопинк, европлекс, обладающий группой горючести Г1;
      -отражающая теплоизоляция на основе вспененного полиэтилена, полиэстера с двухсторонним и промежуточным фольгированием, для сравнения возьмем теплоизоляцию, обладающую группой горючести Г1.
      Для того, чтобы сделать правильный выбор утеплителя для строительства Вашего дома, проведем небольшое исследование по приведенным выше параметрам выбора материала.
      Для оценки свойств и качеств утеплителя будем использовать 5-бальную шкалу.
      1. Теплоизоляционные свойства - не все знают, что тепло теряется не только через теплопередачу (посредством прикосновения 2 тел друг к другу), но и через тепловое излучение и конвекцию.
      Соответственно, для достижения эффективной теплоизоляции, бороться нужно со всеми этими тремя факторами одновременно.
      Стоит отметить, что потери тепла через стену разделяются примерно следующим образом: 65-80% приходится на тепловое излучение, 15-28% на тепловую конвекцию и лишь 5-7% тепла теряется посредством теплопроводности.
      При потерях тепла через кровлю, 93% тепла теряется посредством теплового излучения, остальная часть тепла теряется посредством теплопроводности.
      Потери тепла через пол: 50-70% тепла теряются посредством теплоизлучения, 5-7% - посредством теплопроводности и до 45% - посредством тепловой конвекции.
      А потому при оценке теплоизоляционных свойств каждого материала будем учитывать 3 приведенных выше параметра.
      Оценка утеплителей за теплоизоляционные свойства:
      Минераловатная или базальтовая изоляция (неплохой коэффициент теплопередачи К=0,04 , но не обладает отражающими свойствами и требует применения дополнительных мембран) - 3 балла;
      Полистирол (неплохой коэффициент теплопередачи К=0,04, но не обладает отражающими свойствами, так же, как и минераловатные утеплители боится высокой влажности и атмосферных явлений )- 3 балла;
      Экструдированный пенополистрирол (хороший коэффициент теплопередачи К=0,03, но не обладает отражающими свойствами, не боится атмосферных явлений)- 4 балла;
      Отражающая теплоизоляция на основе вспененного полиэтилена (отличный коэффициент теплопередачи К=0,011, в том числе за счет высоких отражающих свойств - 97% теплового излучения, равнодушен к атмосферным явлениям, влажности воздуха, так же является эффективной ветрозащитой)- 5.
      2. Срок службы.
      Минераловатная или базальтовая изоляция (50-60 лет + обладает высоким влагопоглощением, вследствие чего теряет свои изоляционные свойства, так же в некоторых случаях может являться средой обитания грызунов) - 3 балла;
      Полистирол (25-30 лет + может быть средой обитания грызунов и обладает высоким влагопоглощением, вследствие чего теряет свои изоляционные свойства) - 2 балл;
      Экструдированный пенополистрирол (25-30 лет + не обладает паропропусканием, что отрицательно сказывается на конструктивной части стены) - 2 балл;
      Отражающая теплоизоляция на основе вспененного полиэтилена (100 лет) - 5 баллов.
      3. Экологичность. В настоящее время все более важным аспектом при выборе любого материала становится его экологичность. Как раньше, люди не гонятся за самым дешевым и как следствие - самым низкокачественным продуктом. Забота о семье и своем здоровье является одним из важнейших аргументов при выборе утеплителя. Поскольку никто не хочет дышать вредными испарениями и разрушать свой организм.
      Минераловатная или базальтовая изоляция - 5 баллов;
      Полистирол - 5 баллов;
      Экструдированный пенополистрирол - 5 баллов;
      Отражающая теплоизоляция на основе вспененного полиэтилена - 5 баллов.
      Оценка 5 баллов присвоена всем материалом, основываясь на том, что они являются оригинальными и сертифицированными, от проверенных производителей.
      4. Пожаробезопасность. Является важнейшим показателем выбора утеплителя, поскольку именно от нее зависит безопасность Вас и Вашей семьи. При строительстве жилых помещений используется утеплители группы горючести НГ и Г1.
      Минераловатная или базальтовая изоляция (НГ, Как известно, сам камень не горит, однако смолы, входящие в состав клеевой смеси, горят и выделяют в воздух отравляющие вещества. Кроме того, прекрасно горят ветрозащитная и пароизоляционная пленка составляющие конструктив минеральной ваты.)- 4 балла;
      Полистирол (Г1) - 4 балла;
      Экструдированный пенополистрирол (Г1) - 4 балла;
      Отражающая теплоизоляция на основе вспененного полиэтилена (Г1) - 4 балла.
      5. Стоимость. Материал невозможно оценить исходя лишь из стоимости кв.м. утеплителя. Для объективной оценки стоимости материалов нужно подобрать их толщины с одинаковыми теплотехническими характеристиками и сравнивать стоимость толщины утеплителя на кв.м., а так же нужно учесть необходимость применения дополнительных мембран и сложность монтажа.
      За основу возьмем 100мм минеральной или базальтовой ваты, это равносильно 100 мм полистирола или 70 мм экструдированного полистрирола, или 20 мм отражающей теплоизоляции (пр-ва Южной Кореи - модель Prime Cell - материалы российских производителей не обладают необходимой группой горючести и теплотехническими свойствами).
      Минераловатная или базальтовая изоляция (100мм ≈ 486 руб. + 40 руб. мембраны + трудоемкий и затратный процесс монтажа ) - 2 балла;
      Полистирол (100 мм ≈ 387 руб., сложность монтажа и необхоимость применения герметиков) - 4 балла;
      Экструдированный пенополистрирол (70 мм ≈ 500 руб., сложность монтажа и необхоимость применения герметиков) - 3 балла;
      Отражающая теплоизоляция на основе вспененного полиэтилена (20 мм ≈ 400 руб., простота монтажа, система стыков материала продумана производителем) - 4 балла.
      Подведем итог:
      Минераловатная или базальтовая изоляция 17 баллов;
      Полистирол 18 баллов;
      Экструдированный пенополистрирол 18 баллов;
      Отражающая теплоизоляция на основе вспененного полиэтилена 23 балла.
      Наиболее эффективным методом утепления жилых помещений является применение отражающей теплоизоляции на основе вспененного полиэтилена.
      Но при выборе материала не стоит забывать о том, что не все материалы примерно похожие внешне, являются идентичными и по качеству. Например, большая часть, представленной на российском рынке отражающей теплоизоляции, является очень горючим и как следствие опасным материалом, применять такие материалы попросту не безопасно.
      Так же стоит учесть тот факт, что материалы различных производителей обладают различной степенью сопротивления теплопередаче, это обуславливается несколькими факторами:
      1. "алюминиевая фольга" не всегда является таковой, зачастую ее заменяют на металлизированную пленку, что снижает отражающие свойства материала в 1,5-2 раза.
      2. специфика производства не у всех производителей одинакова, одни делают подложку под ламинат и утеплитель для систем вентиляции - в лучшем случае, у других - структура материала разработана таким образом, что основным назначением является утепление фасадов.
      3. немаловажное значение имеет вопрос соединения стыков материала. Большинство проивзодителей предлагают материалы, стыки которых соединяются путем сваривания строительным феном или же посредством нахлеста одного слоя материала на другой. Но есть и модели теплоизоляции с уже предусмотренной заводом-изготовителем системой стыков, что упрощает и удешевляет монтаж, а так же исключает необходимость утолщения слоя материала.
    • Автор: IVD
      Какие новые составы разработаны производителями для отделки потолка?
      [media=]
      [/media]
    • Автор: IVD
      Почему возникают трещины в гипсокартонном потолке и можно ли этого избежать?
      Допустима ли установка гипсокартонного потолка во влажных помещениях?
      Как быть, если в результате протечки на гипсокартонном потолке образовалось пятно?
      Какие светильники могут быть установлены в такую конструкцию? Существуют ли какие-то ограничения по мощности ламп?
      Как долго в среднем монтируют гипсокартонную конструкцию?
      Как правильно транспортировать и хранить гипсокарнтонные листы?
      Дают ли монтажники гарантрию на установку потолка? Какие случаи повреждения считаются гарантийными? Есть ли гарантия на материалы?
      [media=]
      [/media]
    • Автор: IVD
      Какие компоненты включает в себя система подшивного гипсокартонного потолка?
      Каковы минимальные потери в высоте потолка в случае установки подшивной гипсокартонной конструкции?
      Каковы преимущества и недостатки в отделке потолка штукатуркой или гипсокартоном? Какова стоимость работ этими материалами?
      Нужно ли крепить полотно подшивного потолка не только к потолку, но и к стенам?
      Верно ли утверждение, что стыки гипсокартонных листов должны приходиться только на несущие профили?
      Как следует грамотно заделывать швы между плитами?
      Может ли потолочная конструкция иметь криволинейные формы?
      Какими красками может быть окрашен гипсокартонный потолок, и есть ли ЛКМ, которые ему противопоказаны?
      [media=]
      [/media]
